That must be frustrating because I find strada on my 580 to be unusable for me and it shifts up quickly so I can’t imagine it being more sluggish. Maybe a tune is in order?
Use Strada Auto in my 580-2 in bumper-to-bumper traffic and never experienced your issueHi everyone, just got my 2021 evo delivered. When the car is in Strada it goes up to 6th gear really quickly, when trying to speed up the car stays in 6th and feels like it’s bogging down. To get the gear to step down you have to go through the kickdown, which drops it down aggressively to 2nd/3rd which isn’t ideal when travelling in traffic. Does anyone else experience this in their Evo? I’m being told this is a feature of the new gearbox and not a fault. Having had 3 Huracans previously I find that hard to believe as none previously did this?
This !You're not alone! I have a 2021 EVO RWD and have experienced the exact same issue after a few days into ownership. I even have detailed the concrete steps to reproduce this problem and have communicated them to both my dealer and the Lamborghini North America Customer Relations lead. The dealer was also able to reproduce this problem following my instructions on another EVO RWD they have in stock. The Lamborghini NA customer relations lead basically said that this behavior is normal and expected, but that he would pass along my feedback to the factory. Fingers crossed if there'll ever be a gearbox software update to fix this. IMHO, the current gearbox programming in Strada is very dangerous. I have had multiple occurrences where the vehicle would not pick up in 6th gear at low speeds without me having to downshift manually.
This is standard operation of the 2021 Evo. I admit to using the paddle shift to get a lower gear that feels better in the rpm range but then you have to reset to get back to automatic mode which requires turning the car off and restarting. I have been able to adjust my driving habits but there is a learning curve for this feature.Hi everyone, just got my 2021 evo delivered. When the car is in Strada it goes up to 6th gear really quickly, when trying to speed up the car stays in 6th and feels like it’s bogging down. To get the gear to step down you have to go through the kickdown, which drops it down aggressively to 2nd/3rd which isn’t ideal when travelling in traffic. Does anyone else experience this in their Evo? I’m being told this is a feature of the new gearbox and not a fault. Having had 3 Huracans previously I find that hard to believe as none previously did this?
i don't know what you mean with resetting to get back to automatic mode, if you wait 10 secs it automatically gets back to automatic.This is standard operation of the 2021 Evo. I admit to using the paddle shift to get a lower gear that feels better in the rpm range but then you have to reset to get back to automatic mode which requires turning the car off and restarting. I have been able to adjust my driving habits but there is a learning curve for this feature.
I'm referring to manually shifting down to a lower gear. I'll double check that but mine doesn't seem to reset after 10 seconds.i don't know what you mean with resetting to get back to automatic mode, if you wait 10 secs it automatically gets back to automatic.
if you put the car in manual mode via paddle shifter and it doesnt go back to auto you can hit the M button on the center console to switch back. You dont have to turn the car off and back on. That button will toggle from Manual to Auto whenever you want.I'm referring to manually shifting down to a lower gear. I'll double check that but mine doesn't seem to reset after 10 seconds.
