1 - 1 of 1 Posts
Greetings all,
I have the above mentioned car for sale in Dubai. Brand new, yellow in colour. Specs are below:
CHASSIS AND BODY
Frame:
Carbon fiber monocoque with aluminium front and rear frames
Body:
Carbon fiber engine bonnet, rear spoiler and side air inlets; Aluminium front bonnet, front fenders and doors; SMC superlight rear fender and rocker covers
Mirrors:
External mirrors heated, electrically adjustable and foldable
Rear spoiler:
Fixed spoiler in carbon fiber, manually adjustable with 3 position (high-mid-low down force)
SUSPENSION
Suspension:
Front and rear horizontal magneto-rheological damper with push-rod system
TYRES AND WHEELS
ESP:
ESP/ ABS with different ESP charecteristics managed by drive select mode
Steering:
Steering Gear with 3 different servotronic charcteristics coupled with Lamborghini Dynamic Steering (LDS), managed by drive select mode
Front tires:
Pirelli PZERO Corsa 255/30 ZR20
Rear tires:
Pirelli PZERO Corsa 355/25 ZR21
Front wheels:
9”JX20” H2 ET32.2
Rear wheels:
13”JX21” H2 ET 66.7
AIRBAGS
Airbags:
Front dual stage driver airbag and front adaptive passenger airbag; seats with side “head-thorax” airbags
BRAKES
Brakes:
Dual hydraulic circuit brake system with vacuum brake booster; front and rear CCB, (6-cylinder brake calipers, 4-cylinder brake calipers); Ventilated discs (front – rear): Carbo-ceramic discs Ø 400 x 38 mm – Ø 380 x 38 mm
ENGINE
Type:
V12, 60°, MPI
Displacement:
6,498 cm³ (396.5 cu.in.)
Bore and stroke:
Ø 95 mm x 76,4 mm (3,74 in. X 3 in.)
Valve gear:
Variable valve timing electronically controlled
Compression ratio:
11.8 *(± 0.2) : 1
Maximum power:
750 CV (552 kW) @ 8,400 RPM
Maximum torque:
690 Nm (507 lbft) @ 5,500 RPM
Engine speed, maximum:
8,500 RPM
Engine speed, idling:
850 RPM
Emission class:
EURO 6 - LEV 2
Emission control system:
Catalytic converters with lambda sensors
Cooling system:
Water and oil cross flow cooling system with fixed air inlets
Engine management system:
Lamborghini Iniezione Elettronica (LIE) with Ion current analysis
Lubrification system:
Dry sump
FUEL CONSUMPTION
Urban cycle consumption:
24.7 l/100 km
Extra urban consumption:
10.7 l/100 km
Combined consumption:
16.0 l/100 km
CO2 emission:
370 g/km
DRIVETRAIN
Type of transmission:
4WD with Haldex generation IV
Gearbox:
7 speed ISR, shifting characteristic depending on drive select mode
Clutch:
Dry double plate clutch, Ø 235 mm (9,25 in.)
Standard:
AMT
PERFORMANCE
Top speed:
>350 km/h (>217 mph)
Acceleration 0-100 km/h (0-62 mph):
2.8 s
Acceleration 0-200 km/h (0-124 mph):
8.6 s
Acceleration 0-300 km/h (0-186 mph):
24.0 s
Braking 100-0 km/h (62-0 mph):
30.0 m
DIMENSIONS
Wheelbase:
2,700 mm (106.30 in)
Overall length:
4,835 mm (190.35 in)
Overall width (excluding mirrors):
2,030 mm (79.92 in)
Overall height:
1,136 mm (44.72 in)
Front track:
1,720 mm (67.72 in)
Rear track:
1,680 mm (66.14 in)
Dry weight:
1,525 kg (3,362 lb)
Weight/Power ratio:
2.03 kg/CV (4.48 lb/CV)
Weight distribution (front - rear):
43 % - 57 %
CAPACITIES
Fuel tank capacity:
90 l (23.8 gal.)
Engine oil capacity:
13 l (3.4 gal.)
Engine coolant capacity:
25 l (6.6 gal.)
If anyone is interested, you may reach me via call or Whatsapp on +971 56 637 6928. The vehicle is as indicated above.
Thanks
1 - 1 of 1 Posts
