Engine
Type:
V12, 60°, MPI
Displacement:
6.498 cm³ (396,5 cu.in.)
Bore and stroke:
Ø 95 mm x 76,4 mm
Valve gear:
Variable valve timing electronically controlled
Compression ratio:
11,8 (± 0,2) : 1
Maximum power:
700 HP (515 kW) @ 8.250 RPM
Maximum torque:
690 Nm (507 lbft) @ 5.500 RPM
Emission class:
EURO 5 – LEV 2
Emission control system:
Catalytic converters with lambdasensors
Cooling system:
Water and oil cooling system in the rear with variable air inlets
Engine management system:
Lamborghini Iniezione Eletronica (LIE) with Ion current analysis
Lubrification system:
Dry sump
Performance
Top speed:
350 km/h (217 mph)
Acceleration 0-100 km/h (0-62 mph):
2,9 s
