Thank you for both posts above. I will try the pin/reboot if i need to change battery and see where it goes.I had to reboot the system when I changed my battery.
You can re-boot the radio by doing the following:
1. Turn on the ignition, don't start the car.
2. Turn on the radio and hold down F/M and SET-UP buttons at the same time for 10 seconds. The radio will re-boot and turn back on.
3. Turn the ignition off for 5 seconds and then back on.
This worked for me, and it's worth try. Good luck!
I have tried it multiple times and it has never worked on any radio.You can find on the web for free an iso named "rnse unlock cd" to burn and when inserted in your rnse it will give you the code pin to enter.
No need to pay something.
It's about 15mB
What has never worked ?I have tried it multiple times and it has never worked on any radio.
I have an 09 LP560 that requires a pin code. I had a shop replace my battery and now it’s asking for one. Car does not have the irigibal manual when I bought it. Do I just need to remove the radio and get the serial number somewhere in the back?Pin is basically hard coded to radio. I do believe the radio "pairs" with the car at the factory so that you do not "normally" need to reenter the pin code if you disconnect the battery. If a radio is installed from another car, there is a high likelihood that it will ask for the pin.
I can't guarantee that the pin would never be required with radio in original car.
I can retrieve radio pin codes but have to have the radio in my possession unless you have the serial number from the card.
Pins are all different. 0000 and 1234 are more like bluetooth pairing codes, not radio security pins.
You need the code that starts with "AUZ". Usually you can find it on the pin code entry screen. If not, you have to have software to pull it from the radio. It is not on any label. That is unusual that it is asking for a code, unless the radio is not original to the car.I have an 09 LP560 that requires a pin code. I had a shop replace my battery and now it’s asking for one. Car does not have the irigibal manual when I bought it. Do I just need to remove the radio and get the serial number somewhere in the back?
AUZBZ7H2201108 this is the one that shows up on the radio screen. If it’s something you’re able to retrieve and charge for your time to do please let me knowYou need the code that starts with "AUZ". Usually you can find it on the pin code entry screen. If not, you have to have software to pull it from the radio. It is not on any label. That is unusual that it is asking for a code, unless the radio is not original to the car.
Not sure if I read the old post right but you said you would be able to retrieve the code with that serial number? Or maybe I mistaken and read wrong and it might be someone else…AUZBZ7H2201108 this is the one that shows up on the radio screen. If it’s something you’re able to retrieve and charge for your time to do please let me know
