can you give us more details (pictures?) or what you replaced and what with ?Ive replaced the two map sensors and the car is great now!
Thanks rayman!!
So other than being my new hero, what can you tell us about your cars? Pictures?Actually i have 2 roadsters
Ok, after a bit of searching on the web, it seems they Magneti Marelli Part number is PRT03/04.It looks exactly the same but not sure about the part number , i think it should work
Haha! thanks man, will post pictures after the weather gets cooler! its over 110 degrees here!So other than being my new hero, what can you tell us about your cars? Pictures?
Both works! ill post the old one and the new one.. you should get it from ebay, it will work and its much cheaper. 03/02 is the old one replaced with 03/04Ok, after a bit of searching on the web, it seems they Magneti Marelli Part number is PRT03/04.
I've photo'd mine close up and is says PRT03/04 2738BD - I'm not sure if the last 6 digit number is a date code or part of the part number.
Unfortunately I can't tell from your photos in the forum, whether its the same code 2738BD or not - can you advise please ?
I have emailed Marelli to see what the 6 digit code means.
If it is PRT03/04, they are on eBay for many italian cars for around £20 ($30).
Used as the pressure sensor for the vapor traps.In the meantime does anyone know what the third one is for ?
Where did you see spec of 03/04 vs 03/02 being different?I saw the pics of Nsalsabah and i think these sensors could be different? 03/04 being replaced by 03/02 i think looking at the specs will give a much leaner mixture if im correct. Because it has a wider pressure range than the 03/04 MAP.
