1 - 2 of 2 Posts
This is the 94 VT water pump with power steering . I would like to change the seal in the pump but not sure how to remove it . Has anyone done it before and care to share the steps ? Where shall I start ? I cannot see any nuts that can be removed. Thanks
Leslie, I have not but looking at the part diagram it appears that part 13 is female threaded and part 20 screws into it. Could it be that they are reverse threaded such that they remain tight as the car turns the belt, if so you’d want to unscrew in the opposite direction of the belt travel. But other than that completely unsure. Do report back when you figure the answer. Good luck
1 - 2 of 2 Posts
