I have that with my 06 but only in traffic after driving the car a while. I haven't had it checked out yet u accepted it for now since I know these cars hate traffic
Sent from my SM-G935V using Tapatalk
it only has a map sensor on top of the plenum ? Or am I wrong. Maybe I will clean that up firstYours seems like it may be an actual issue since you have codes. Many others have idle hunting as a result of overly driving like a puss ball which causes carbon buildup on the maf.
I have an obd scantool which works as far as reading and erasing codes.How are you resetting the codes? Did you try resetting then disconnecting the battery for a couple of hours, sometimes that gets things back in alignment for other cars.
Swapped the tb over from left to right. Same codes. Disconnected right side connector completely, same codes lol. Pull the left one and it will add p1227. Any suggestions?
I replaced both TB, all sorted now. But I believe a 2009 has got bosch TB instead of magneti marelli. So not sure it will have the same cause. I sent both my TB to ecu.de and they replaced both potentiometers with contact free ones. They dont wearI have an obd scantool which works as far as reading and erasing codes.
Have you been able to sort this out yet? I'm having a very similar problem on my 2009 right now. P2101 and P2106. Have you tried swapping the accelerator pedal?
