▀▄▀▄ Vivid Racing : GiroDisc Murcielago Brakes : Lambo-Talk Exclusive Member Pricing!
Greetings Lambo-Talk Members!
We are excited to bring you an exclusive Lambo-Talk member offer on all GiroDisc products. Offers to include discounts, package deals, and free shipping. I've listed the full GiroDisc catalog below along with MSRP pricing. To discuss the exclusive Lambo-Talk member offers, please contact me directly via PM, email, or phone. As always, we have our best price guarantee and will match or beat any competitor quote!
-Chris
Chrisk@vividracing.com
480.966.3040 ext 226
Girodisc Front 380mm 2pc Rotor for Lamborghini Murcielago Late (8/4 Pot) : $1500 MSRP
The Girodisc system is a direct replacement for the OE disc. No modifications are necessary. The disc will bolt directly to the car and work with OE calipers perfectly. The factory rotors are 365mm and these are 380mm discs and require the use of a supplied caliper spacer. The Girodisc front rotors are approx 24.5lbs vs. 27lbs for the stock units. By upgrading your brakes with lightweight high performance replacements as opposed to a big brake kit, your factory bias is maintained as well as your ABS efficiency. This reduction in rotational and unsprung weight allows for quicker acceleration and suspension response.
The central hat section of our rotor is made from strictly U.S. sourced 6061-T6 aircraft specification aluminum. The disc is made from our own proprietary cast iron, poured in the USA and machined from start to finish in house at Girodisc. The rotor utilizes a curved vane design, developed in racing to act as a centrifugal pump to force cooling air through the disc.
The rotor and hat have a floating mount system, which utilizes 8 or 10 high strength alloy steel drive pins, manufactured by Girodisc in the USA to our own specifications and cadmium plated for a long lasting corrosion resistance. These pins take the load from braking actions while maintaining the axial and radial float between the hat and disc. The pins are secured by grade 12 cap screws with hardened washers. In order to keep the rotors from making noise when cold, the pins are mounted with anti-noise spring washers on the rotor side which allow the rotor to grow with heat expansion but eliminate the rattle and noise associated with floating rotors. This float also allows the rotor to self center between the pads.
Once the Girodisc system is in place, simply replace the cast iron rotor when needed.
__________________________________________________
Girodisc Rear 2pc Rotors for Lamborghini MurcielagoLate (8/4 Pot) : $1200 MSRP
The Girodisc system is a direct replacement for the OE disc. No modifications are necessary. The disc will bolt directly to the car and work with OE calipers perfectly. By upgrading your brakes with lightweight high performance replacements as opposed to a big brake kit, your factory bias is maintained as well as your ABS efficiency. The Girodisc front rotors are approx 18.2lbs vs. 22lbs for the stock units. This reduction in rotational and unsprung weight allows for quicker acceleration and suspension response.
Girodisc Front 355mm 2pc Rotor for Lamborghini Murcielago Early (4/4 Pot) : $1500 MSRP
The Girodisc system is a direct replacement for the OE disc. No modifications are necessary. The disc will bolt directly to the car and work with OE calipers perfectly. The Girodisc front rotors are approx 24.5lbs vs. 27lbs for the stock units. By upgrading your brakes with lightweight high performance replacements as opposed to a big brake kit, your factory bias is maintained as well as your ABS efficiency. This reduction in rotational and unsprung weight allows for quicker acceleration and suspension response.
Girodisc Rear 2pc Rotors for Lamborghini Murcielago Early (4/4 Pot)
Girodisc Front Magic Pads for Audi/Lamborghini 8 Piston Caliper : $250 MSRP
Girodisc Rear Magic Pads for Lamborghini Murcielago Late (8/4 Pot) : $150 MSRP
Girodisc Front Magic Pads for Lamborghini Murcielago Early (4/4 Pot) : $150 MSRP
Girodisc Rear Magic Pads for Lamborghini Murcielago Early (4/4 Pot) : $150 MSRP
Girodisc "Magic Pads" are the solution to your squeaky, dusty, expensive factory pads. They have less dust than typical factory pads and much less than typical performance pads. You won't be cleaning your wheels nearly as often. Additionally, they have great initial bite, something less expensive pads are lacking. But the real reason people like our pads so much, they are the "silver bullet" to brake noise problems. Magic pads are a semi-metallic composition that is easy on the rotors and the wallet. We recommend always replacing pads as a whole car set when switching compounds.
As a service to our Gallardo customers, we install wiring in the front pad set to facilitate use of the factory pad wear sensor system. Simply plug the bullet connectors from our pads into your factory harness and rest assured knowing your pad wear indicator light will function as it should. Who else would do that for you? All magic pads come with our anti-noise shields pre-installed, included in the price.
Girodisc S/S Front Brake Pads for Audi/Lamborghini 8 Piston Caliper : $325 MSRP
Girodisc S/S 0810 Pads : $200 MSRP
The Girodisc S/S or "street/strip" pads represent the ultimate in high performance brake pads. The semi-metallic compound maintains a consistent coefficient of friction from 0 to 1000 degrees making them an ideal option for people that are looking for a dual purpose pad that will work well on both the street and the race track. The formula has very little compressibility ensuring a very firm pedal and immediate bite which has made the S/S pads a favorite among people who autocross and those who demand the most out of their street cars. Inevitably these will dust more than our Magic pads however with the addition of our anti-noise shims that come on every set of pads they will not make any noise if they are bed in properly.
-Chris
